What’s the reasoning that Bambu doesn’t have the feature either on the machine, in Studio or on Handy to allow filament slot swapping during a print?
I’ve been doing massive prints and my AMS keeps giving me errors about filament feeding issues (when nothings actually wrong) and I’m not home to babysit it. So there are times where i’d like to just say F’ it and tell it to switch which slot it’s feeding from (i primarily run single color).
Just trying to think through my head why this wouldn’t already be a feature.
Seems like all it needs is to be told slot X is empty and it will auto-reload from the next … but in my experience things that seem easy become hard when you see how the actual code is implemented, which is usually why it hasn’t been done yet.
Are you getting AMS errors from one particular slot? Then either fix it or don’t use that slot on long prints.
If you’re getting AMS errors on all slots, how is remotely switching the filament going to help, won’t a different slot just error out also?
The answer here is you should want to fix the AMS error instead of looking to slap a bandaid on the problem.
Please share as much detail as you can about the specific errors and we can try to help you with that.
To your main question, this could technically be done, but would require a fair bit of work to add this functionality to the printer, the ability to be controlled via the cloud, and some extra stuff in the sliced file’s G-code. As usual, it seems straightforward in one very narrow use case, but when all the different factors are considered this becomes a bigger lift.
Does it add value? A little bit, but in practice most people aren’t planning for a feed failure and loading multiple spools of the same filament into their AMS units.
The errors are random and inconsistent and i’ve yet to pinpoint the root cause. Regardless of my specific scenario, i think the ability to tell the machine to swap slots remotely would be valuable to many users.
Say if you get any filament error and you try the age old “click to resume” button a few times and it doesn’t work itself out and you’re not nearby to fix it. But if you could go into the app or log into Studio and say unfeed the current slot and then pick a different slot to load it would give the users a way to keep their machine running.
I realize you cannot even do this on the machine interface currently. You have to “trick it” into thinking it ran out. So yes, there would need to be some software devlopment done first to the machine and then the app/studio, but i doubt i’m the first one to wish they could pause their machine and tell it to just swap slots.
