Tall thin parts
Hi group
If i wanted to vertically print some thin plates that were say 150mm wide x 1mm deep and then 150mm high with some hole features in them, and I wanted to print them vertical and a few on the build plate stacked closely together but needed to support them so the hole features didn’t wobble etc during the print especially as it gets higher up.
other than painting supports, is there any cool features or other software that will handle simple supports in between each vertical part over say 20 parts?
like a programmable honycombe structure that can be easily removed?
Looks like your best bet would be to design the supports yourself into the model, then you can place the plates close together and support them in your design.
