Hi everyone,
We are currently using the H2D printer calibrated with the Vision Encoder in conjunction with Bambu filaments. However, we are experiencing significant issues with tolerances on the stock profiles. For example, when printing a part that should measure 150mm, we’re seeing inaccuracies of over a millimeter, resulting in parts that measure only 149mm. For instance, when using Bambu ABS, we’ve found that a shrinkage value of 99 is necessary. This means that, with the stock profiles, a part intended to be 300x300mm actually prints at 297x297mm, resulting in a tolerance discrepancy of 3mm. Additionally, the holes we print are consistently undersized.
Despite using properly dried Bambu filaments and Bambu Studio latest version and filament profiles, we find ourselves having to manually calibrate each filament. After calibration, we can achieve tolerances of ±0.05mm, which is excellent. However, the time and cost associated with calibrating each filament and nozzle size adds up quickly. Our primary focus during calibration is on filament shrinkage and the auto circle contour hole offset (which needs to be set to -0.15 i.e. for ABS).
Has anyone else encountered similar issues? I must admit I’m quite disappointed. I had hoped that using Bambu filaments (including PLA, ABS, PA6-GF, and PETG) would minimize the need for extensive calibration. From now one we are switching to cheaper alternatives since we need to do the work anyway.
