Text Depth in model
Is it possible to configure the Text Tool default thickness to be a certain value. Currently if I click the Text Tool on an empty plate it automatically drops the word “Text” onto the build plate along with a thickness value. Right now, on my machine it is set to 2.00 mm…
Can I change that setting permanently to a different value?
While it would not really be of use to me, can you change the default text that drops on build plate?
If I was making parts on production it might be beneficial to put a lettermark or wordmark text as the default so it would act as a pre-configured part. Instead of the default being the word “Text” it could be “@JohnDoe” instead
Add a primitive then select the text or move it over the model
for the other options to appear
To clarify, 1) I did not know that so :+1:
Here is a graphical version of my question.
On selecting New Project, the Text Tool is enabled right from the start so I can drop text on an otherwise empty build plate. I want to get from picture 1 to picture 3 without the intervening picture
Here is that picture, the tool is enabled but not yet selected.
Upon selecting the Text Tool, I get the Text Tool pop-out with the Input text being Text
I’m wondering if there is some type of configuration file where things like my question can be changed by changing the configuration file without blowing up Studio.
