I previously created some box inserts with labeling on them that looked great. I went to print the same exact project and now it’s wiping the text. Did something update? I cannot figure out how to get it to do this again and I’ve wasted like 3 hours so far between bambu studio, tinkercad, and freecad trying to do anything remotely similar. I don’t want a pocket because I want it to be actually colored and I can’t do an extrusion because the other side of the face won’t be able to print flat.
These are the settings from the project when it worked:
Its hard to know what you have tried, This can get really confusing for me sometimes. If I understand what you are trying to do this works for me.
Put the text on the bed side of the print so it is flush with the square. Originally I just added text then lowered it below Z and it took priority, now if I do that it tries to float the square a few mm so it doesn’t actually print, or if I make it flush it does this weird thing where it prints as both filaments at once (???)
Try making a negative text lower than the layer height (.01) and it should print it without an indent/pocket.
What I show in the image above does what I think you are asking, I have it facing up so you can see it. note I have “modifier selected
Modifier did the trick, IDK how it worked before or if it was set before how it got unset but it’s working exactly as expected, thank you so much
I am having the same issues but I am using modifier I have wasited WEEKS on this!! can you tell me the settings you’re using?
