The a1 is a disgrace to the bambu lab name. i hate the a1
Hey everyone,
I’ve been in the 3D printing hobby for a while, starting with a MakerBot Replicator 5th Gen, and eventually moving to Creality printers and beyond. I currently run a small print farm with 20 P1S printers and sell full-time on Etsy, Amazon, eBay, etc.
However, I’ve been extremely frustrated with my experience using the A1 series printers. Last year, I bought four A1 Minis, and by the third week, all of them stopped extruding properly—clogged nozzles, extruder issues, you name it. Then, I tried the regular A1, bought two of them, and experienced the same problem after about 10 hours of use. There was also a heat bed recall, which ultimately led me to sell all six units just to move on.
Recently, I decided to give it another go and bought eight more A1s (without the AMS Lite system), thinking perhaps the wall-mounted setup with AMS Lite was the issue. I planned to dedicate these machines to printing PETG exclusively. Sadly, within 10 days, only five are working. One machine didn’t even load a single strand of filament—the extruder gear clicks right out of the box. I’ve had an open support ticket since the 10th, still waiting for a response.
I’ve attached some photos to show what I’m dealing with—there seems to be a serious issue with these machines. They work fine for a while, but then the nozzle gets clogged, and the filament barely extrudes. Even after cleaning and performing cold pulls, it feels like there’s some kind of obstruction. It’s baffling that this has happened to 9 out of the 14 machines I’ve tried.
For context, humidity is not an issue in my print room (30% average), and I go through a new roll of Sunlu PETG every two days. I print at 250°C, but even after lowering to 220°C, the problem persists. My older A1 Minis with AMS Lite had same issue eventually, using the same PLA that I run through my X1 Carbons and P1S machines with no problems.
I spent eight hours today scraping PETG off the textured plate because the A1 managed to extrude just enough to fuse it to the surface in the worst way imaginable. I’ve reached a breaking point with these machines.
attached video is what my life is like now, using included filament stand, no joint issues, all 8 are setup exactly the same so i know its not a setup issue with the tube guiding etc.
Has anyone else experienced similar issues with the A1 series? About to deal with returning 8 a1s and biying p1s like i should have.
and if this post seems ai generated, i had to run it through chatpgpt to take out the 30 profanities i had in my original post.
fml
Roughly how many prints are you getting before having issues?
20 hours, extruder working fine with nozzle removed and no clicking. i dont know how im clogging nozzles like this if thats the case. using sunlu petg, generic petg settings in the slicer.
I’m not familiar with the A1 but the X1C came with Bambu filament samples. Have you tried printing some calibration or other example pieces using the Bambu filaments and Bambu profiles just as a test?
will do, will test out the new hotends i have coming in tomorrow, i have a feeling that will fix the issue, but for how long. and what is sunlu petg doing to the hotends to destroy them with less than 30 hours on them. will update
Been running my A1 everyday for around 10hours a day for 2months now and touch wood no issues at all. Friend bought one recently and also no issues, I have no idea, very strange to hear this.
thanks for the insight, im sure the issue has to be me as everyone seems happy with the a1s
I’ve had excellent results from my A1MINI, ~175 hours printing. Mostly Bambu PLA basic, but I have printed some anycubic PETG in red(not a very nice red, and rather shiny), but it did print well. Also printed quite a bit of sunlu PLA silk lately.
I can’t imagine so many printers having the same issue, probably one common denominator, filament or moisture or tolerance. There’s a bunch of pretty fart smellers here that can no doubt get you lined out.
I have 1,000 hours on my A1 mini, I had 1,000 hours on my A1 before the recall.
No issues on either.
I jammed a nozzle, it was my fault.
I have no idea what you are doing to these printers.
The fact that you have the P and X series printers which you clearly have no problems with confuses things.
I just can’t see so many printers experiencing the issues you described without you being the common factor.
This could be the choice of filament, handling, settings, no idea, but, so many failures in two different ranges over three lots of printers over two different timeframes doesn’t lend itself to build errors or manufacturing issues. There are too many factors that I would look to include or exclude for ruling in or ruling out issues.
Without knowing in detail what you have been doing, for how long, with which material and what settings in what temperature housing and so on, it will be impossible to guess.
Reading here about the number of issues people have who own the A series, is low, very low.
They are well built machines and work horses.
youre absolutely right, everything points to something im doing being the failure point, but the real kicker was one of the 8 brand new ones in this last set not worknig right out hte box when i just did the same thing for the other 7. ive narrowed down the issue to nozzle clogs. which is crazy for 3 clogs to happen in 1 week of printing imo. going to return these and get p1s. which is what i should have done from the start. heck my first x1c has over 8000 hours and i havent even changed the nozzle on it yet. thank you everyone for the replies/help!
Have you read this…??
Do you have one of these air quality monitors that provides temperature and humidity info? I’m curious want the ambient temperature is because if it’s too warm, there could be heat creeping up the machine and reaching filament before it enters the nozzle which would generate clogs and other mishaps.
I have a very cheap version of that lol. the room is the constant variable in this equation, it gets up to 95 degrees f in there at night with all the printers running.
with it being an open enclosure and the p1s and x1c never having an issue with the doors open even printing petg and abs i ruled that out, but maybe the a1 is more sensitive to heat creep?
when i get these new nozzles and hopefuly get everything working ill run the industrial fan i have in the room 24/7 and the portable ac in there every hour to keep it under 85 to rule that out going forward.
I only own the A1 Mini, so I can’t speak to the P1S and X1C, however Bambu recommends not enclosing the A1’s which is probably due to multiple reasons with one of those being heat creep. Also do both the P1S and X1C have additional fans for circulating some of that chamber air? This would be missing on the A1 Mini and A1.
The easiest way to test is to bring the room temperature down a bit and see if you still get these print clogs. For reference I run my A1 Mini in a small room that I keep around 77 F with no clogging issues.
The common denominator in all these failures is… you?
Fair play to you Socal3d for saying it could be you and not getting mad about that, real nice to see someone say it could possibly be them.
The ONLY thing I can think is… when you load PETG, do you change the filament from PLA to PETG on the printer its self before loading it? If not, im wondering if this is giving you some issues as the loading temp/purge is different to PLA.
I think this needs to be stickied, stickyed, stuck…whatever to the top of this forum.
See, not so bad to say you could be the problem…
but that title thou…
Hello Socal3d
Sorry to hear you are having all these issues. can I ask you mentioned your room humidity is 30% but do you have/use a dryer with filament prior to use?
Your room environment might also be the cause…
Check this out:
Your going to get bias opinions on this board… my X1C has been the least reliable printer I own
