Things Josh is Designing/Printing (Formally Mega Swatches)
Will it hold its position with weight on it? I could think of some uses if so.
Will adding springs or elastic bands help propel a baby sized child if required and how far?
I am asking for someone else.
Seriously, just about every time I open up this thread Iā€™m like ā€œWhat the f***!ā€. How do you seriously turn out these amazing designs so quickly? You are a machine.
Been putting together an inventory of Makerā€™s Supply hardware for myself with all the things I think I can start doing cool stuff like this with. All for when I actually have time this fall/winter to work on making stuff again. Keep doing what you do, itā€™s quite inspiring.
He is a witch, there are remedies for that.
Shhhhh :shushing_face:
Hereā€™s 30lbs on it!
Thatā€™s a different project :wink:
Ah man, Iā€™ve got a lot of printing ahead of me to put together the samples for this. I have a few extra things to tweak too.
I like to think I havenā€™t even yet got fully crazy with the things I could make. Iā€™ve had a few ideas floating around in my head for a minute plus that Iā€™d like to execute some day.
I think thatā€™s a good idea. Iā€™ve been putting together an inventory of Makerā€™s Supply stuff too, and itā€™s been helpful in the design process. It has opened my mind up a little to different ideas.
Like these! Smooth Ball Spring Plunger Hmm, I wonder what I could do with these. :thinking: Iā€™ve been thinking about it. I do love my case designs, so it seems like the perfect hardware for some sort of case.
These are on my next purchase list.
I have already received some Ring LED Magnetic Control Switches, 2 Wires Slip Ring 12.5mm with SH1.0 Connectors and from elsewhere, Arduino controllers, LED matrix displays and strips.
I want to mix some real electronics into a project.
Did you make that thread for the spool using a Fusion thread and rounding it out, or did you use a sweep or other feature?
I was thinking the same about making my own threads because it seems like the only way to print Fusion made threads without problems is to use variable layer height, or a small layer height for the whole part.
I used the coil tool. I didnā€™t do anything fancy as far as sweeps though. Iā€™ve been finding that the coil tool seems like the best approach for plastic friendly threads. As easy as the threads tool is, itā€™s not got any good 3d printable thread profiles, I feel.
As Iā€™ve been getting more comfortable with Fusion itā€™s been getting easier to whip threads up.
On another note. Hereā€™s a use for an old A1 bed, if youā€™ve got one kicking around. I fashioned mine at my plate cleaning spot, to help keep the plate in place while I wipe it down!
Thanks for the info, I did a test in Fusion to check it out, it looks like it will be great. Iā€™ll definitely try the coil tool next time I want to make a thread.
Iā€™ve almost been thinking about doing some Fusion tutorials. Speaking of. Could be neat to show how Iā€™m approaching threads now. Among other things. I was thinking maybe itā€™d be useful, as itā€™d be 3d printing focused topics.
@Josh-3D inspires many people to steal their neighbourā€™s printers to harvest the bed to mimic his workflow.
Well, I mean, haha. It is working out well!
I have one of these detail sanders from Milwaukee. I just stick a micro fiber cloth on it, and boom! Quick actinā€™ plate cleaninā€™ fun.
Uhh, I mean, so far today itā€™s working out for me. If I come complaining about how my build plates are all messed up though, feel free to reference this moment here where I thought I was oohhhh so clever.
How hard do you hit the build-plates? Do you have a triangle above square shape indentations anywhere on your build-plates?
Havenā€™t had to do that yet. After the gantry Iā€™ll pass for a bit.
Hahaha, not yet.
I was using this. A micro fiber cloth wrapped around a drill brush thing. Iā€™d throw the plate on the floor and give it a go. It kind of worked, but I still had to give a hard wipe down from time to time.
so far the detail sander seems like itā€™s doing better. I havenā€™t tried eating a greasy cheeseburger, handling my build plates, then cleaning them. So Iā€™m not sure likeā€¦ how well itā€™s doing exactly. In my prints today though Iā€™ve not had issues, so.
I wonder how folks that have larger print farms handle their plates. I like this developing approach, as it is helping with efficiency when dealing with used plates. Even just having a magnet base to put the plate onto has made it way easier when doing a manual wipe down.
Do you find it does a significantly better and faster job at cleaning the plate? I havenā€™t considered using power tools to wash my plates, but maybe it could get off that residue I have from the Bambu PLA Matte.
I see this going in a very bad ā€œTool Timeā€ direction.
When are you releasing this? Or have you and I just missed it.
Iā€™ve found a use for it.
I was aiming for this weekend.
Be warned though, it does make use of hardware. It uses 25 bearings, a thrust bearing, m3 self tapping screws, 2 M8 nuts, and a 120mm M8 screw, for the small size. I think the medium is going to be 150mm.
Bearing count might end up at 26-27 though, as Iā€™m thinking of adding a little crank to the wheel to make it faster to spin.
Iā€™m dubious as to how affective it is using a power tool. I want it to be helpful/useful, but I havenā€™t convinced myself of it yet. The White PETG-HF was giving me fits just now too, so itā€™s got me questioning things.
Having a solid place to put the plate, with holding power, has a bigger actual impact though. It does make it easier and faster. It helps me keep my fingers off the plate while cleaning.
What I need to do is print some PLA silk and see how it does with that. Anytime Iā€™ve printed PLA silk, it leaves a noticeable shadow of plastic from the print just removed.
Many adult themes here.
Feel free to call me stupidā€¦ (pause for everyone to do that) ā€¦ What would people do with this?
Have you used any exotic material (beyond PLA/PETG) to achieve the weight capabilities?
