Throttled points/downloads?
Been stuck on 3700 downloads for 4 days now and nothing moving but my other counts seem to be fine… am I being throttled or overlooking something? I even tried to promote it to see if i coudl advance the count past 3700 and nothing… @Tanklet @BambuLab anyone with an answer?
3700
hi. are you using “unofficial makerworl assistant” plugin? it’s not a makerworld problem but a plugin problem. when it reaches 3/4k downloads it freezes but the count on makerworld continues correctly
that may be it i also posted the count in image above albeit its tiny that shows the 3700 achieved on 4/20… ill look into the actual makerworld stats too and see if thats the case
check also full analytics of the model…
It can’t accurately depict the downloads because of the abbreviated stats. Since MW only displays increments it takes 2(1k) + 1.7k = 3700.
That’s a browser plugin issue not a MakerWorld issue
It isn’t, it is a MW issue.
The plugin reflects the data returned by MW.
You can see one example here where MW is clearly using generic values above a certain number.
The plugin can only work with what it was given.
