Looks to me like “just” an oversight. The P1S generic profiles simply haven’t been updated to account for nozzle flow differences, or even exist in many cases. And no mention/support for the E3D nozzle variants at all.
Deep dive:
If one looks at the available filament presets (in user config folder or just the app distribution/source), there are only 2 “Generic” profiles with “P1S” in the name – Generic PETG HF and Generic PC. There are some more with “X1C” in the name, but which list P1S in the list of compatible_printers property of the file.
With P1S printer and 0.4 nozzle as the project machine, selecting any of those filaments (with specific P1S/X1C profiles) to edit will show the regular/HF flow selectors up top.
However selecting a Generic type for which there’s no specific P1S-compatible profile will revert to the observed behavior of (apparently) only having one setting for all flows. In such cases the slicer defaults to using the Generic _____ @base.json profiles as the starting point for all filament settings.
Notably, there are no P1S-specific profiles for any PLA type besides “Generic PLA High Speed” (for X1C, with P1S listed as compatible).
Looking into the profile contents, we can observe that the ones which have P1S-specific configs (and present regular/HF choice) all have the configuration directive:
"include": [
"fdm_filament_template_direct_dual"
Whereas the @base profiles do not.
As one might guess, this includes the contents of the specified file (plus “.json” extension) as if it were part of the profile with the “include” directive. The included file is just more filament settings which are shared by several profiles, and in this case “dual” refers to flow types (not number of extruders), and sets the profile up for multiple flow types, specifically the filament_extruder_variant property in there:
"filament_extruder_variant": [
"Direct Drive Standard",
"Direct Drive High Flow"
If we look at any of the “Bambu” filaments, there’s a P1S-compatible profile for all of them (either directly with “P1S” in the name or listed as compatible in “X1C” profiles).
Then there’s the E3D nozzle… if there’s one available for the P1S then it seems to be a neglected child. I don’t see it in the “Flow” choices for that printer, and none of the BL filament profiles list that as a choice for P1S, although they do for P2S.
For reference, if we look at any of the “P2S” profiles, we’ll see they
"include": [
"fdm_filament_template_direct_dual_e3d"
And the contents of the included file have
"Direct Drive High Flow",
"Direct Drive E3D High Flow"
Some of this info becomes somewhat practical if one is willing to edit/create profile config files manually. Syntax and care are important, but ultimately they’re just text files – make backups and such. Unfortunately we have to restart Studio for it to pick up any manual changes/edits.
I wouldn’t “force” the E3D choice onto a P1S filament profile manually since that’s not an option in project settings when using P1S (the slicer will likely never use those extra properties anyway). Although the really adventurous could look into the “machine” config profiles’ printer_extruder_variant property…
Doing a side-by-side compare of P1S and P2S machine configs can be interesting, in any case.
Cheers,
-Max
