Toolhead camera initialization failed - always on second print
In the X2D the live view camera is used to read the build plate. If the last print left build plate lower in the cabinet, the live view camera cannot see the build plate ID TAG. Thus evey time I would get the same error you all describe. I found that if I HOME the printer before sending a new job all is good. Maybe this is similar enough to work. Good luck to me, my H2C arrives tomorrow.
You see, an error in reading a buildplate code and an error during camera initialization are two completely different things. They should not be conflated. The issue being discussed here is not a buildplate code reading error. Furthermore, the camera mentioned here is not a liveview camera, and the printer in question is NOT an X2D. So, I’m sorry, but you’re a bit off-topic here…
Perhaps others earlier in the thread were off topic a bit and I was misled on what the main topic is. There seems to be alot of back and forth about many aspects. I merely threw out a possible issue with what was mentioned much earlier in the thread. No need to be a snark about it. Have good life.
I gave it a try for a while. Unfortunately, your suggestion didn’t provide a solution for my h3c either. Thanks anyway. I hope a solution that actually works comes along.
I’m pretty sure the problem lies somewhere in the communication between the components, and I suspect only a small number of H2C units are affected.
Based on my testing, I suspect the issue might be related to communication between the AP board and the MC board.
My theory is that Bambu Lab may have reused some of the H2D electronics in the early production batches of the H2C, which could be causing compatibility or communication issues. Of course, that’s just speculation at this point.
I’ve spent quite a lot of time troubleshooting my H2C, and so far, nothing has permanently resolved the problem.
I believe replacing both boards and, most importantly, the cable connecting them might resolve the issue. However, that’s still something that needs to be tested.
If anyone has already replaced both boards and the connecting cable, I’d really appreciate it if they could share their findings.
The electronics across a single series of printers are highly standardized. The main control board (AP board) is identical for both the H2D and H2C models. The print head contains two boards: the primary one (housing the microprocessor) is the same for both, while the second one (which controls the heating elements) differs between the H2D and H2C. The cameras connect to the primary print head board, and data is transmitted via the microprocessor directly to the AP board (the intermediate/MS board is not involved in this process). I would recommend checking the camera connectors and ribbon cables within the print head; even if everything looks fine visually, there could still be issues with the solder joints (which can be verified under a microscope). As a last resort, I would replace the primary print head board—there is a 99.9% chance that the problem lies there (either with the connectors or the soldering).
I purchased my H2C in March this year, and by mid-April, I started getting consecutive errors for the “Nozzle Camera” and “Toolhead Camera.” The HMS error codes were HMS 0C00-0100-0002-0014, HMS_0500-0600-0002-0002, and HMS_0500-8092 093001. In June, I had both the “Nozzle Camera” and “Toolhead Camera” replaced through my distributor. However, the same errors popped up again just a few days later. After submitting a support ticket to inquire about it, Bambu Lab suggested that I replace the “TH Board + USB Cable” directly. It was a massive project, but I managed to swap them out. Since then, the “Nozzle Camera” and “Toolhead Camera” errors haven’t appeared at all during printing. I highly recommend opening a support ticket to replace the “Nozzle Camera,” “Toolhead Camera,” and the “TH Board + USB Cable” altogether. It will make your life so much better!
Just as expected. The root cause of the problem is most likely the TH (toolhead board) —not in the camera or the cable.
