Hi!
I recently got a P1S and am liking it, but I noticed that when a print finishes the tool head parks outside of the poop shoot, causing filament to ooze out while the nozzle cools (especially with PETG and some other stringy brands).
When starting another print the printer then moves to the poop shoot, starts purging some filament, but sometimes the stuff that oozed out outside the shoot “hooks” on the shoot making the poop not fall, getting stuck in the shoot.
Here’s an example. Filament oozing out:
and here it is hooking on the side of the shoot:
(tool head is outside the shoot here, it already did the shaking to make the filament fall down.)
You can also see the filament inside the shoot, hooked to it by the bit that oozed out before. Manual intervention is required here, with me unhooking the poop from the shoot.
Is there a reason why the printer doesn’t park the toolhead inside the shoot to prevent this? Did somebody already write some modified end gcode to do this?
It’s one of the first things that I noticed, sice the printer almost always parks the toolhead there while the nozzle is hot and it is such a simple fix, that I thought it was just an oversight.
Did adding the G-code fix the issue without any side-effects? I just got this printer and have the same exact issue where it parks just to the right of the shute.
