Toxicity of filaments
what are the high temps you need? I ask because some PLAs actually offer over 100C annealed!!! such as the ones proto pasta makes which is a HTPLA .
ABS is not great for high temp btw. PC and some of the others you mentioned can be good though. Just have a window to vent or some air filtering.
I am buying the X1C in a few weeks and one of the first things I did was devise my plan for ventilation. I bought a fan for the window to pull the air outside, and will fill the empty space around the fan so no air will come into the room from that window. I am also going to print a hood to put above the X1C with a fan and pipe directing the air toward the window fan, so I catch the fumes if I need to have the top open.
The window fan is the most important, an open window by itself can sometimes make things worse. Wind can blow air in causing the fumes to spread to other parts of the house. If another window is open in the house, this can sometimes cause the air to flow in from one window and out from the other, which could be good or bad depending on direction of the flow. I prefer the fumes take the shortest route out of the house so I don’t breath any of it on its way out.
By having a fan in the window (or wall), you create negative pressure in the room, causing it to suck the air from any other openings into the room, preventing the fumes from escaping through doors.
People shouldn’t wait for warnings to protect themselves from unnatural fumes, the possibility of harm is too high to take a chance. It is better to find out your precautions were not needed, then find out your lack of precautions were damaging. Especially since sometimes precautions once considered useless are later found to be necessary.
My DIY window exhaust system :). Even though the printers are in their own room, If I print any materials other than PLA, I am more at easy to have the fans on pulling the air out. It’s a reversible window fan (not expensive). Anyone who has installed window AC before would know how to install. The fans are covered when not in use. The cover is a foam from Home Depot that was cut to size and put inside a plastic bag to prevent outside moisture from soaking it. The fastener are some big strong rubber bands (I had to split it in half lengthwise to make it less strong), also from Home Depot, that are anchored to some nails on the top and bottom of that window frame. The cover seals well. I don’t feel any draft from it. If there are foot traffics near the window, or small chilfren around, it would be wise to wrap them up in some protective stuff so they don’t snare and cut and cause injury.
My window Is a smaller basement window that can fit a single fan. In addition to filling the empty space with foam encased in a 3D printed part, I am going to make a cover like you did for the fan opening when it is not on. I plan to print the cover with foam inside that has some rubber weather stripping so I can push it against the fan and have the rubber seal prevent air from leaking.
Have you considered 3D printing some parts to cover the foam?
I haven’t printed anything for this DIY project. It was a quick and fast solution when I did it last winter to vent while stopping the cold from getting inside. The combination of the foam and rubber bands push and mould the foam onto the fan for a very good seal.
I print mostly PLA. So occasionaly taking off 3 rubber bands and putting them back on is not a big deal. The room is used by the printers only. I have no plan to work on this further at the moment.
I see my own post in this thread on Apr 18 just about when I got my printer a week after.
I remixed a 4" vent model to fit the AMS Hub. X1C 4"/100mm Straight Exhaust Vent (AMS-hub compatible) by ant | Download free STL model | Printables.com
It is easy to print and install. I used it in addition to a Bento Box inside the chamber. I printed about 800 hours in the X1C this way. At least 700 hours was polymaker ASA.
I sold my X1C recently, and I have the X1E coming in a few weeks and it is supposed to have built in filtration. Guess what, I’m installing my 4" vent adapter and going to vent it outside anyways.
If anyone is telling you not to worry about melting plastic and it’s safe–I will tell you it only takes a little bit of effort to vent to outside through a window or something else for that peace of mind. It does not affect print quality to vent outside. Just do it.
Not sure this is fully accurate. Can you point me to a MSDS that suggests PA is carcinogenic? Not calling it outright wrong, just that I haven’t seen that. In Bambu’s MSDS for PAHT (PA 12), it states it has a very low probability (less than .1%) of being flagged as carcinogenic.
That said, burning plastic can’t be good for anyone, so people should treat it appropriately.
Yes and is it food safe and from a no smoking factory?
Hey, I just got Bambu Labs Carbon x1 to print prototypes of my ventilation product. I have kept mine in the garage but what do you think about this product to ventilate vs the rig you have setup? - Check out getvyana website
I am not looking for ventilation product at this time and can’t do any comparisons or proudct reviews.
Thanks for the quick response! Loved the ventilation rig you built. :slight_smile:
Hi, please see my design, an Active Carbon Filter System with an integrated Heating Element!
I know this is an old post but given literal lives could be impact I’m going to revive this since it showed on a top search. There have been scientific studies that effectively do not conclusively prove but come to the conclusion we should not rule out the possibility of the carcinogenic effects. In addition, ABS contains styrene which is classified as a probable carcinogen. Given your choices are “properly vent” which should fall under “normal processing circumstances” or take your chances. You should take pre-cautions to avoid breathing it.
I use the bento box 2.0 in my x1c and the VOXELPLA hepa carbon filter. And then i put on covers over the poop chute and the other air vent in the back near the chute to stop unfiltered air from getting out. Then I tape the front of the door with painters tape (I should probably start taping the top too). I still smell some when printing but it is a lot better than before and the readings on my air quality tester stay in the safe range.
Here’s a study I found comparing ABS, ASA, Nylon, and PETG.
It kind of makes it sound like nylon isn’t as toxic as people make it out to be. They even recommend it, alongside PETG, as an alternative to ABS and ASA when proper ventilation may not be an option. I wonder if a sealed chamber and a recirculating carbon/hepa filter really is enough for nylon to when venting isn’t an option. Thoughts?
As an update to this thread: ABS, ASA and many other higher grade plastics are indeed toxic. Whether or not a plastic is carcinogenic is a different topic. A carcinogen is something that causes cancer. Cancer is not the only dangerous thing out there. A VOC can be toxic but not carcinogenic. If you find a study as noted earlier in the thread that shows that ABS for example is not carcinogenic that’s wonderful but it isn’t the whole story. That study does NOT mean there aren’t other dangers, typically neuro-inflammatory or respiratory dangers. The MSDS for ABS for example states these phrases:
Emergency Overview The ABS sheet is not expected to be an inhalation hazard under normal processing conditions. If material is processed under prolonged exposure to flame or high temperature, thermal burns to The skin may occur, and gases may be produced that are irritating to the respiratory system. (What is a “normal processing condition” in a plastics manufacturing plant? Its not melting the plastic, its cutting it they are speaking of).
Chronic Effects of Exposure to High Temperature and Thermal Decomposition In October 1988, the National Institute for Occupational Safety and Health (NIOSH) found insufficient evidence to classify Styrene as a Carcinogen (this phrase means it doesn’t cause cancer, nothing of any other effects. It also speaks only of the styrene component, not the others. And when melted, the elements that are released into the air are chemically different than when the product was solid.)
Hazardous Decomposition Products Carbon Dioxide, Water, Carbon Monoxide, Hydrocarbons, Hydrogen cyanide and possibly some original monomers (styrene and acrylonitrile) are released as fumes and vapors when processing the sheet at high temperature and exposure to flame. (As I mentioned above these are the other agents released upon subjection to intense heat. All toxic.)
Section 11 Toxicological Information Chronic Effects on Humans No specific information is available, but no ecological hazard is suspected. (This is where you find the loophole. No information available simply means no one has produced a study on it. That does NOT mean it is safe.)
In short if it smells bad you should trust your body. Your sense of smell was designed to trigger an abhorrent feeling when something is to be avoided. Trust it always. If it doesn’t smell at all then only trust the science you can find on that material. Read between the lines as well. Scientific studies are typically very specific in their objective and not all-encompassing. They also require willing participants. Not easy to come by. Most of what we know about the human body came from psychopathic scientists in the dark ages and all the way up to the 20th century who tortured prisoners, insane asylum detainees and immigrants. So don’t be shocked to find out that we don’t actually know something as a people. Err on the side of caution.
Thanks for the write up - makes sense
I need to find more info about PC-CF or PET-CF with respect to needed ventilation, I don’t really have a option of ventilation at the moment. Been only printing petg and pla for ~6 months without issues in my office, but yeah I need better temp performance
