OK so bought the FTS and have it installed and finally got it working right. Hey Bambu news flash… Maybe adding a motor to the switch would make it feed more reliably, just a thought.
So with the switch installed am I able to use an external spool through the TPU ort n the H2D?
Welcome back!
I know it seems like a simple solution to this complex problem, but Bambu just adding a motor to the filament track switch won’t work - all feed motors also need a control mechanism to tell it when to turn on and off.
That’s why all AMS units have to be fed into a buffer in the first place.
Using the existing buffer signal to control both the AMS and this hypothetical extra feed motor isn’t an easy solution either as each of the three AMS options feed at different speeds - the proposed motor would have to somehow match that.
Using a dedicated buffer and feed motor within the current buffer and AMS stretch also won’t work as it will result in a feedback loop where the two units fight each other.
At the moment, per all the Bambu documentation and many threads in this forum, external feeds don’t work while the FTS is enabled, you have to disable it to use external spools or a TPU assist. Bambu is working on a way to enable both.
Thanks
I feel like with Bambu R&D they could come up with a better solution but I am tired of worrying about it.
And I will say this, since Bambu replaced my H2D I can say it has been a big pleasure to use this printer.
I’m actually kicking around some ideas with another forum member for a solution, but that’s a ways off yet.
For now the best bet is to have the smoothest PTFE tube setup possible.
Good to hear your new printer is working better.
