TPU Assist module filament pathway
I’m thinking of obtaining a TPU assist module to help with printing. I took a look at the Wiki and assorted documents that detail how to assemble and install the module. I currently use my external spool holder on occasion to print. I’m not sure, but, it appears that the ptfe tube pathway that the external spool holder uses would conflict with the TPU assist module installation. Do they use the same input point into the P2S?
I am using the module and it works great. It gets installed on the machines right side and the filament goes in bypassing the feeder that the AMS unit would use. The feeding tube is changed from the AMS one to one coming off of the TPU feeding unit.
Thanks for your reply. Would you mind posting an image of how your connections in the back of the printer are attached? Are you using an external spool holder also?
I don’t see an image. Did you mean to post one?
