Tree Support branches from vertical walls without altering Top XY Distance?
Hi everyone,
I am facing an issue in Bambu Studio where my tree support structure is fusing horizontally with completely vertical outer walls of my model.
Here is the dilemma:
  • The vertical wall is 90° straight.
  • The tree branches are printed way too close to this wall and melt into it, ruining the surface finish.
  • I cannot increase the global XY distance, because doing so also pushes the support interface (the contact area under the actual overhangs) too far away, causing the overhangs to sag or fail completely.
What I have tried so far without success:
  1. Tree Organic: It gives better clearance on the vertical wall, but it changes the support interface pattern/area at the top, which I need to keep exactly as it is for a flat surface finish.
  2. Support Blockers: They only prevent support generation under overhangs, but they do not cut away the branches/trunks that grow upwards right next to the vertical wall.
  3. Increasing branch angle (to 55°/60°): The branches still hug the vertical wall too closely.
Is there any hidden setting or workaround to force a larger horizontal clearance between tree support trunks/branches and vertical walls without breaking the critical XY distance at the interface layer? It seems like Bambu Studio lacks a dedicated “Tree Support Wall Distance” option that acts independently from the interface XY distance.
Any help or trick is highly appreciated!
Thanks in advance.
Your .3mf (or a similar file with the same problem) would let us review your settings and find a solution.
Your support Top Z distance seems rather large (0.5 mm); 0.1 mm is typical without a different interface material.
I often reduce Support/Object x/y distance to 0.15 mm to stabilize tall, thin models; they do not touch or fuse with the model at all.
Körper1.3mf (778,9 KB)
I use PLA as the interface layer.
That’s why my top Z-distance is set to 0.
The 0.5 mm you see is the bottom Z-distance, which, in my view, doesn’t have any impact.
I misread the top Z-distance translation; sorry about that.
I think you found a bug in Studio. When I load the project in Studio (Beta 2.8.4.57), it does not respect your 0.35mm support-object setting. The Preview shows that the supports clearly touch the model on layers two through seven (top). Orcaslicer (bottom) builds different supports that do not touch.
The orange reset arrow returns the gap to the default 0.2 mm, and the support still touches the model. Entering larger values, the support finally stops touching the model at 1.0 mm. But I can then type a value as small as 0.02 mm, and the preview will show a gap between the support and model.
If I save the project after the supports are “unstuck” and then reload it, the supports again touch the model.
Try setting a gap of 1 mm or more, slice the model, verify the supports are not touching, then set the gap back to the default 0.2 mm.
If I increase the X/Y distance from the support/object, they no longer fuse together; however, the gap between the interface layer and the part also widens (which isn’t what I want, since it should fit tightly when using interface material—or PLA, in my case).
Should a case like this be reported to Bambu Studio? I’m fairly new to 3D printing and have mostly just read the forums until now.
