Triple heatbed force sensor failure
Hello,
Recently I got the following errors regarding the heatbed force sensors:
0300-0a00-0001-0005
0300-0b00-0001-0005
0300-0c00-0001-0005
I followed the troubleshooting guide from the BambuLab wiki but nothing seemed to fix the issue.
Then I remebered that this all started after one of the nearby buildings got hit with a lightning, after that event some of our devices connected to the electricity at that moment start to have some issues (one of our PCs SSD was damaged, one of the two elevators in the building was damaged as well, and the garage door too). Anyway, I suspect that the sensors might be damaged but I do not know how to prove it.
Also I do not know if it is only the sensors or also their respective circuit boards? Is there any way I can troubleshoot the sensors in order to check wether they are damaged or not?. Every other aspect of the printer seems to be fine.
Best regards
I dare say the best approach would be to open a ticket to ask bambu to analyse the log file. If anywhere, it should be the best source for analysis. But only Bambu can read and interpret it.
