Hi everyone, recently received my P1S and AMS 2 Pro.
I am on my first roll of filament which is eSun Black PETG, I have done every calibration I could possibly think of, dried the filament for 12 hours at 65°C in the AMS 2 Pro and I can’t get a good print in sections, images attached. I am printing with the lid on and the door shut as well. Would love to hear your ideas please!
Hello,
these areas, are the seams? Check this in the slicer,
may be retraction related. In this case check also your ptfe routing
from ams to the hotend also you can upper the retraction value to 2mm and
try again
P1S will be supplied with (half a roll of) BL Basic PLA. Does that give better results?
Door open and/or top off for PLA, PETG, and TPU.
Second this.
Unless your room temperature is about 10-12°C so that open door would introduce cold draft and cause some weird artifacts or corner lifting.
Thank you for that, it’s worse with the door open or the top off.
Will give that a try thank you.
Just checked in the slicer and the affected areas are not near the seams. Haven’t changed the retraction yet thank you.
Good afternoon, I was wondering if you managed to sort out the issue? I’m also printing with eSUN PETG and am having the same problem on the H2S. I’ve tried printing at both 245°C and 230°C, with an outer wall speed of 60 mm/s, overhang speed of 30–50 mm/s and overall speed of 150 mm/s, but I’m still having the same problem.
Try these settings, worked great for me! Bambu Lab X1 Carbon PETG Settings - Get Perfect Prints
