Turn off H2S chamber LED after print
I know you can turn the chamber LED off anytime, which disables AI failure detection, which is less than ideal. Why is there no option to allow the light to automatically turn off if the printer is idle?
Can we make that happen?
Isn’t it like the H2D where in settings you select “auto-sleep” to the time you wish and select “energy-saving mode” for the chamber light mode?
A solid…maybe? I have not seen that setting…but even then is it the usual wait x minutes, or just a hard when printer finishes also turn off the LED?
Yes, the light will turn off after the time you specify between 2 and 15 minutes.
And on the H2D at least, a touch on the screen, the opening of the door switch the light back on, don’t need to go into menu to switch it on.
While still better than staying on, why not just have the option for immediately?
