@SupportAssistant there’s a typo on the wiki page for H2D bed tramming that will be confusing for less experienced users.
In the middle of the text, at “Start Leveling” chapter, the text incorrectly states “Insert a leveling feeler (such as a 0.1 mm metal shim or paper) between the nozzle and the bed” while the animated picture correctly shows using the printed 2.0 mm “feeler gauge”.
Please forward to whoever can edit the wiki.
Thank you for sharing.
It does not really matter how thick the feeler is as long it is the same one used when leveling. But we will do the necessary corrections to make it clearer.
True but 2.5 mm is so very far from 0.1 mm that you’d need to unwind the screws like 9 full turns. If the threads are even long enough for that the hotplate will be very tilted between first and second point, increasing the risk of misalignment or worse problems.
Also many people don’t have feeler gauges, which is assumingly why it’s suggested to print the 2.0 mm one.
