Unable to print a single box with even walls
Ok. … this!!
Test-prints work with 0.16 goo enough for it not being visible under normal circumstances.
When printing the actual Cube, being it the A1M or P1S it does not work @ 0.16mm
Next try: High-flow Hotend with CHT Nozzle on P1S
Hello,
i am a bit late but maybe you have already solved the Problem.
I had the Same Problem and found the following solution for printing boxes.
I cut the Box in 2 pieces right after the last layer of the inner Bottom. So One Part is only Bottom and the other part only the walls. The bottom Part left with default setting.
The “Walls” Part I set:
Wall lines=1;
surface pattern=concentric;
pattern of the lower surface=concentric;
lower shell layers=6
I use the 0.20mm Standard @BBL A1 setting and made the custom setting from that.
Maybe you can try it and it helps.
Greetings Philip
Hey @Phil4
sorry I’m so late to your response, I’ve been off the community for some time.
That’s a very interesting approach… which sounds super interesting.
I’ll get back to you as soon as I have tried this.
Thx a lot in advance! :smiley:
