Absolute genius, thank you for sharing. Just did this with a part that’s been driving me crazy. You’re a lifesaver.
Thank you, that sorted out the problem i was having
You are very welcome, despite not providing me with a reason to milk it with a large (entirely unnecessary) image.
Thanks! once I figured out to select the objects on the side panel and move… its awesome! thanks!!!
You are welcome.
It is possible. Merge the two objects, then switch from GLOBAL to OBJECTS view. There you can select the object you want to lift, Click on the MOVE icon and now you can lift it off the build plate with the Z-Axis arrow.
Gracias nunca me ubiera imaginado que asi era la opcion, un abrazo
This works without merging: https://www.reddit.com/r/BambuLab/comments/y19jnk/bambu_labs_snapping_to_build_plate/
Another hack is to add a positive part to the object you want to lift, and you can make it a tiny 1x1 part and put it somewhere in the corner out of the way. As long as that part is on the bed, you can move your actual object anywhere you need.
