Hey guys, for some reason I get a horizontal line on my prints where the filament does a swap to PLA for support interface and when i looked at the sliced information I see that same horizontal line under layer time (horizontal green line in this attached image).
So what would i need to change and where to be able to have a uniformed outer layer?
package.3mf (34.6 KB)
Thanks. Yeah i understand that but that was the only place i saw the same line I get when its done printing so figured that would be causing it. Here is the attachment maybe you can see something i dont. I print it on petg and the interface in pla .
Changing back and forth between PLA and PETG too many times. I suspect, it didn’t purge clean enough, so a bit of molten PLA now bleeds into PETG while continue printing in PETG.
You should change your design so that the overhang surface is level with XY plane then only 2 layers of interface is needed, so that only 1 time change between PETG and PLA.
