I’ve printed this part on my Bambu Lab A1 with seam position set to the back. Where do these nearly symmetrical marks come from?
From nozzle clog check where the toolhead travels to the corner and then back - it leaves such marks. Disable that check and the print will be smooth.
I feel a bit stupid now, but where exactly should I deactivate this? I can’t find an option called “nozzle clog check”.
It’s called “nozzle clumping detection” check the article here:
In order to disable: on printer screen click “setting” then “Print option” and uncheck “Nozzle Clumping Detection”
I found it, thank you so much.
