Just thought I’d post about this, since it took quite some time for me to figure out.
I had issues where apparently the bed leveling often didn’t work very reliably. I’d notice this with problematic first layers.
It turns out that this was related to the Jayo matte PLA that I used. While that stuff can be printed at very high speed, it also has the downside of oozing from the nozzle while it’s cooling down right before the automatic bed leveling procedure (at the start of every print). You have to watch this like a hawk and remove that dribble before it has time to start the actual bed leveling, otherwise it will interfere with the sensing. I tried modifying the gcode (adding more wipes before it’s fully cooled down/the dribble has stuck harder to the nozzle) which helped significantly, but it didn’t cure it every time.
Bambu matte PLA (for example) does not have this problem. I guess it’s one downside of high-speed PLA in general (although this particular filament isn’t actually advertised as high-speed: it just is). I also find that the Bambu matte PLA sticks a little bit better to the bed than the Jayo.
Bambu P1S @4495 hours, Bambu 0.4 mm hardened steel nozzle, cool plate super tack.
