Unsupported file format in raw files upload
I’ve been making models that use microcontroller boards that run CircuitPython. End users need to load the files on their own microcontroller boards.
I had been zipping everything up and uploading to the raw files section of the model page. I just did a bug fix and configuration change and tried to upload it to some models and now the uploads fail with “Unsupported file format detected.” messages.
If I can’t upload these files the models become worthless/non-functional.
The CircuitPython libraries and code have various extensions. It all used to work. @MakerWorld - blocking these uploads means I can’t update software or post new models.
Any way you can make this stuff work again? It’s a change that happened in the last week or so.
Here’s an example. It’s the zip file in the raw files section.
There was malware being distributed in zip files, so the security settings update is what is likely the cause for your issues
I would recommend you create a public GitHub repo with your code and then link that in the description of your models, as I don’t think makerworld will (or should) make the platform subject to this possible abuse from bad actors again
I figured it was going that way. I didn’t want to maintain two repositories but ah well.
Wasn’t aware of the zip file issue. Why we can’t have nice things.
