Use full build plate PLUS supports?
So having an issue w/ my H2D.
I want to print a model that will need to be the full build plate size. I did some figuring out, and one of the workarounds to force it to use the entire plate is to “paint” the left nozzle filament on the left side. I was able to get the model to slice properly doing this. Silly but whatever.
The next challenge? Supports.
Supports appear to only want to print from ONE nozzle. So if you need supports across the right nozzle / middle / left nozzle - it slices and then won’t print, because bambu studio is saying “left nozzle is printing supports, and it can’t print supports in the right nozzle area.”
I can’t figure out a fix for this.
Anyone got a workaround?
You can always build the supports into the model!
That means getting better at CAD but I can try!
