Using Variable layer height change behaviour of Tree Supports
Hello,
I’m trying to use variable layer height on a model that requires supports. I’m using tree supports, which work pretty well for my application. However, when I enable variable layer height, it seems that both tree supports and regular supports are being generated. This doesn’t seem normal, right?
Here are some screenshots with different settings:
Normal model:
Slicing using tree supports no variable layer height:
Slicing using tree supports and variable layer height enabled:
Slicing using only normal supports (but I don’t want to use this configuration):
Supports settings:
Current Bambu Studio version used: 1.10.1.50
Thanks in advance if you have any idea or information on how to combine variable layer height and tree supports.
Okay, I might feel a little bit stupid. How does it go? RTFM, right?
Using “Tree Slim” settings solve my issue…
Nice, I was searching for the same :grin:
But nevertheless it’s weird that style “Standard” behaves different with and without variable layer height.
