When using my P1S on mostly the bigger prints, it always makes a very strange and loud resonating noise when moving from left to right in the X axis, sometimes/less when moving from right to left.
Already tried changing to monotomic but here it does the same diagonal from top left to bottom right.
Tensioned the belts 2 times, ran a vibration compensation calibration a couple times but nothing seems to help.
When i hold the printhead while printing in the X axis it stops for a while, but after 10/15 seconds it starts again. Already removed the head cover and checked and tightend al the small hex screws inside.
Am i missing something here? I think its probably the carbon rods that run a little dry since they get 0 lube/grease while the steel Z and Y rods get it.
The noise isnt the real problem, the artifacs seen on the print are, while making the top most layer it’s not visible because with 50mm/s it doesnt make the noise, but still.
Possible maybe, but wouldnt it make noise in every direction then? En how to check for damaged nozzle? The prints come out véry nice/high quality still.
I am also having an issue that maybe related, It is like a low level rumbling from the printer near constant to the point that i can’t hear the fans over the noise.
Using my phone (So loose measurement) I am seeing just over 60db of constant noise 7ft away from the printer.
I can’t really hear where is is coming from at all, I have tried going round all screws and making sure they are tight, Doing a belt alignment and tension and adding sound deading to the side panels but not really helped.
