Was fine, Now idk what its doing, zits blobs after firmware update
I was able to get my computer working.
I completly uninstalled bambu studio and removed data.
I then did a fresh reinstall of Ver 2.6.0.51(it was mentioned to work in the post earlier)
I have printed mutiple object that where causing problems before and are not now.
I have not tried any newer version yet as I need my printers working well and dont have time to test.
I have the same issue on my X1C and H2D since the last update
Well, I thought this was fixed but it just resurfaced today. I don’t understand
TLDR: removing one line from some configs in a couple of places to fix the issue or print without time-lapse mode seams to fix issue.
I think I finally figured out the issue at least for my X1C(and likely the H2D). After many upgrades and downgrades of the studio versions I noticed a line in the configs that was not there before.
both the configs in the Bambu studio install directory “C:\Program Files\Bambu Studio\resources\profiles\BBL\machine” and the “AppData\Roaming\BambuStudioBeta\system\BBL\machine” had the line “farthest_point_timelapse”: “1”.
this was not in any of the working version, it also only seams to be in the 0.4 size nozzle files
  • “Bambu Lab X2D 0.4 nozzle.json”
  • “Bambu Lab X1 Carbon 0.4 nozzle.json”
I looked in a couple other printer and nozzle sizes and did not find it.
  1. I did a test print of a file and it had the issues.
  2. I tried printing without time-lapse on and it printed fine.
  3. I then closed all Bambu Studios and deleted the lines from the config files.
  4. did the same test print with time-lapse mode on and it printed fine.
I believe this should fix issue but would love to see if it works for others.
Hi,
Thanks for your investigation.
I can confirm that your suggested change fixed the issue with one of my failing prints.
Hopefully this will not become active again in a future update.
Thanks for your work. Have you submitted a bug report for this?
no I did not submit a bug report
I changed this value to “0”, it also worked.
Someone submitted this bug on github 2 months ago. Timelapse trigger pauses print head mid-outer wall causing surface blobs · Issue #11691 · bambulab/BambuStudio · GitHub
After checked .json files, only A series are not affected.
