More specifically FTPS (port 990 / implicit FTP over TLS). Username bblp. Password is the access code found on the LCD in the WiFi settings. Does not require LAN-only mode.
FileZilla Quickconnect example (note ftps:// before the IP address):
Ok I successfully connected to my P1P printer in lan mode. I created a folder on the Card and uploaded from the MicroSD card to my computer using FileZilla
But I cannot upload to the card
Status:
Connecting to 192.168.1.102:990…
Status:
Connection established, initializing TLS…
Status:
TLS connection established, waiting for welcome message…
Status:
Server does not support non-ASCII characters.
Status:
Logged in
Status:
Retrieving directory listing…
Status:
Directory listing of / successful
Status:
Starting upload of C:\Users\denwa\Desktop\bbl.gcode
Command:
TYPE A
Response:
200
Command:
PASV
Response:
227 (192,168,1,102,7,232)
Command:
STOR bbl.gcode
Response:
150
Error:
Transfer connection interrupted: ECONNABORTED - Connection aborted
I just tested creating a directory and uploading to it and it seemed to work without issue. I also uploaded to the root, however I did get one connection interruption like yours. I cancelled and tried again without issue.
Forcing Passive mode can be done on the connection profile but it doesn’t seem to help. The issue seems to be with filesize. Small files work okay but larger ones don’t want to transfer
I logged a bug that trying to upload files > than ~256kb resets the printer. Which really sucks if it’s mid-print. Luckily I was only printing a blocky benchy to see how well the hard overhangs worked in practice.
Sounds like you need to do the firmware update. Try powering off the printer using the switch at the back, then powering it back on after a moment. It will prompt to update.
