Hello everyone,
I need some help here… I have my P1S for about 2 years now and the printer has been nothing short of a work horse.
However, a couple of days ago, I was printing some commissioned parts for a friend and the after the 3rd part (they are the same), I started seeing issues with the first layer, where the nozzle drags over the filament.
Interestingly enough, it is always on the same area of the plate, which I thought would be a dirty plate, although this NEVER happened before with the Cool Plate Supertack as this plate is actually very forgiving. Nevertheless, I took it out, washed with hot water and dish soap, gave it a nice scrub with a blue Scotch sponge, dried it out and put it back. I restarted the print and, sure enough, the issue was there again, same spot.
Second thought was the worn out nozzle, after all, it has been printing for years almost daily. Even though I did not think a stainless steel nozzle would be worn by PLA and PETG, I decided to changed it and finally upgrade it to a hardened one. Again, I made sure to rewash the plate, put it back, reslice the part with the new config accounting for the hardened nozzle only to see the issue again on the exact same spot.
Last but not least, I changed the filament. But the problem remained the same.
If I do not print on the area, the prints come out perfect.
To me, it is starting to look like that, somehow, the gantry alignment is no longer parallel tot he bed, although this should be compensated by the bed leveling.
Has anyone seen a similar behavior? Any ideas on how to fix this?
