I have printed this part about 20 times with no issues but after a month this issue has developed. Im printing with Fibreron ASA-CF using Bambu presets. It’s been working fine and my last 3 prints have all failed due to the support area layers not fusing together. The rest of the part is printing fine. It mainly happens in one spot but 1 attempt it happened throughout the entire area of supports. I have tried resplicing, changing nozzles, and build plate. Nothing seems to fix it and nothing has changed the result. If anyone has seen this or has suggestions it would be really appreciated.
Is it the same gcode, or is it the same file newly sliced?
If it’s the latter, did you run an update of Bambu Studio since that last time?
Ive printed the part so many times I dont recall if I updated the firmware since my last print. I did update presets recently. I remember there being a prompt for the update and I allowed it. If that is the issue do you know of a way to verify what my old priest or firmware was when the prints were working? I can say that I opened a saved file that I always use and tried printing when it failed I tried reslicing. I even tried recalibrating the filament thinking there was a change in the quality of the spool.
The body itself looked fine, so I guess the half-finished part is not brittle or anything. Probably something has changed only related to support structures.
Definitively one of the more wonky area in the slicer. Some of those preset/version changes, specific to support, will affect “unedited” old files. It has happened before. That’s my thought absent more concrete info. (FYI the surprise changes before had to do with other aspects of support, but Rectilinear (default) support bodies crumbling is new to me)
IMO you can try 1. use a cheap filament to test the same scenario. Does it also fail on other filaments? 2. “debug” it on a small test model using the same filament and (albeit time consuming) watch over the printer as it prints those supports (physically, not via live feed)
Ive had a ton of issues but they were all related to filament adjustments never had a slicing or hardware issue. Ive been pretty impressed on how little I have had to do to get good prints. I am going to try changing the base pattern for supports to rectilinear grid. I hope with the cross pattern it will help the layers stick together and allow them to melt together. The only other thing I can think of doing is to make the support line 2 lines thick instead of 1? Not sure how to do that though.
So I tried printing a test piece with the same features that are in my part simulating the supports that are failing. The test piece failed as well and it looks like it fails at the same point which is during the long section of support. Could anyone help with this issue. As I stated before this never happened I’ve printed my part several times without issue. I’m not sure how to fix this issue. It appears that the single line support isn’t bonding during the long stretches
The In-app live view is not a good way of showing since it’s somewhat fisheyed, so straight lines will look warped…. And pixelated can distort things.
I’m having a hard time telling if it’s the camera or not but on your support, even lines that did fuse, parts of these looked… slightly wobbly. Have you tried tightening nozzle screws? Both the front H2.0 hex and back side H1.5 hex on the ceramic heating block. Seems you are using the left nozzle so I’d also check the two H2.0 hex on the steel rail that the nozzle rides up and down on (both will reveal itself when the nozzle is moved to the other end)
ASA needs to be dry to print well. Are you drying and how (details)?
I know it’s knee-jerk, but when someone says a print problem has developed over time, has the weather gotten wetter over that month? Humidity up?
One of the issues water provokes is reduced interlayer adhesion strength. I don’t know but support may be more vulnerable since I believe the rates go up when printing support.
Anyway, just curious if you are drying and how.
Thx it’s been dried for over 24 hours moisture was my first thought for sure. I dry it and leave it in the dryer while it’s printing at 70° for 12 hours.I’m starting to wonder if it might be a bad spool cause I just changed the spool dried it and then began printing and came across this issue. when I get home I’m gonna take a better picture of the part but one consistency i’m seeing is that the issue is with the longer support lines. The shorter ones towards the corners don’t have any issues.
OK so kind of embarrassing but I thought I would share just so it was clear what happened. Its simple the filament I loaded was not ASA-CF it was PETG-CF. They were both 3kg spools and obviously looked the same. I didnt realize my mistake until I noticed there was no smell while printing. SO problem solved use the correct filament. Sorry for the waste of time on such rookie mistake.
