Weird (motor?) noise
Printer has this noise when printing supports, sounds like the motor is skipping, but the print comes out fine. it’s not a model issue, since the same file on another P1S doesn’t create this noise.
I’m using the default slicer profiles, but change the support to Tree (Auto)
video of the noise here
Normal on fast rounded paths
but my other P1S’s doesn’t do this?
I don’t hear anything abnormal either.
so the noise that’s most obvious around the 3 second mark, one that sounds like kekeke, like rapidly skipping motors is normal…?
guess i’ll ignore it for now…
I’ve turned it up and all I hear are regular sounds.
It sounds like skipping but the result is good, so it’s just the input shaping doing it’s job. A new frequency sweep cal might change it, the place the printer is sitting on probably will too.
