Weird noise on X2D z axis
Hi this is the cross post from Reddit and it seems not many people experiencing this issue.
I checked and lubricated all 6 rods and z lead screws but it still made this noise, when homing/moving and even recalibrating. The rods and lead screws seem straight and the machine is cleaned thoroughly. What could be the issue? The video is in the reddit post as I can not upload the mp4 file here
Something’s resonating when the z stepper is hitting a specific frequency. Look for a loose washer, fastener or other small part in the Z axis assembly or where the Z axis components are mounted.
Alternatively, when doing that specific move, you can try touching various components, whatever is doing it will stop making the noise when you’re touching it.
If you’re handy with G-code, it would be easy to make a dedicated program that moves the bed up and down repeatedly at the corect speed to make it easier and safer to do touch testing.
Thank you, here is what I found: https://www.reddit.com/r/BambuLab/comments/1x5vv4s/comment/phimk0v/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
How to make it not slide down like this?
This is actually kind of common for all X/H and maybe even P.
You can see topic from the bambu wiki for the Z assembly. Then you can check and see if you have some kind of bad bearing or you just need to tighten everything.
Usual belt doo not stay in the pulley because there is small angle/pulley is not straight. Or the belt is not tight enough. Usual with some tightening it goes away. But sometimes may need to change the bearing.
Please let us know when you have it fix it and how it was fixed.
Did you resolve problem? I writed support ticket and bambu say its normal “The sound originates from the foreign object prevention silicone sleeve at the bottom of the Z-axis. When the heatbed rises, the Z-axis linear bearing displaces the silicone sleeve; as it naturally disengages and springs back into place, the physical contact between materials produces this noise.”
