Maybe I missed it somewhere (there is a cornucopia of useful information in this thread!) but what is the ideal moisture content for filament, such as PLA or PETG?
Weighing spools to hundredths of a gram before & after drying is a great academic exercise, but on a practical basis (and I publicly admit to being inherently lazy!) I won’t be weighing spools. I haven’t had many problems at all with “wet” filament. When I was using my Prusa i3 MK3S+ originally (and before that, the Anycubic Chiron), with the spool hanging out in the open air, I was printing directly from the eSun drier box. I then enclosed the Prusa in an Ender enclosure, and kept gel packs inside with the printer, and had no problems printing. I’d also run the spool through the eSun drier when done, then seal it in Sistema containers with several gel packs, so that it was dry and ready to roll the next time I needed that filament.
Now with the Bambu P1S with AMS, I keep a bunch of Activated Alumina packs inside the AMS. No problem printing with PLA, PETG or ABS so far. I rely on the Sistema containers (& more recently, the Yashe cereal containers) with gel packs or homemade AA packs, to keep the filaments dry. Haven’t had a need here to keep hygrometers inside each container; I do keep one inside the AMS itself, more out of curiosity than need.
I guess the point I am trying to make is that its easy to go down a rabbit hole about drying filaments, but unless you’re having an issue related to wet filament, I wouldn’t worry about the exact humidity numbers and moisture content. (Should it be 10% or 12% or 20%?) I think the rule-of-thumb is, “Your filament only needs to be as dry as necessary to print without a problem.” Keep your filaments in sealed containers with some desiccant, preferably after running them through a dryer (especially under humid ambient conditions), and you’ll probably be good to go.
For reference, as I sit here writing this at 1:13 am, the RH in this room is 52%. If I take out a spool from the sealed container and place it in the AMS, its exposed to that humidity for all of 30 seconds or so. If the minute amount of moisture that the filament will take on in that short span of time is going to cause a problem printing, then the filament was too wet before I even opened the sealed container.
On a slightly different note, I saw someone posted a note that they were using a repurposed food dehydrator. So I went shopping on Amazon and found a nice unit for under $100 that will allow me to dry at least 2 spools of filament and a tray of beef jerky simultaneously:
