What Glue Stick do you use on the PEI TEXTURED PLATE?
Hi, I’m personally not used any glue stick on PEI plate and with PETG I never had any problem. But whatever the plate you’re using, if you want to add some glue stick do it on hot plate. This way it will be applied very informally. :slightly_smiling_face:
Yo mate,
Just going with the defaults in BLab’s slicer… :crazy_face:
I’m still confused why anyone is using glue on these new engineered build plates. My many years of printing and experience have brought me to cleaning my plates good and then not touching them. They hate dirt and oil. Plus I always use a high bed temp of 55c on all my plates no matter what kind. PETG needs higher temperatures. Are you doing that? Rarely had any adhesion issues. Now with this Bambu technology, wow no issues at all. We are not better at knowing than the engineers who developed these plates. Please say no to glue. Good luck my friend.
If necessary (rarely the case) I use BambuLab Liquid Glue Stick on the PEI plate. Works like a charm with very little residue. Liquid Glue for Build Plate ( PLA/ABS/PETG ) | Bambu Lab EU
My only advice to anyone using Glue, specifically for the cool plate, i come from a world of no glue, im old school however the Bambu team know what their stuff and i can confirm that when using SOME Tri Colour filaments and you dont use Glue the stuff will stick so hard you wont get it off… The glue just helps the release…as for Glue of PEI plate, ive done it once when i had an issue but thus far its been bulletproof with no Glue, just remember if your printing PLA you can turn off chamber fan and just leave door open and enjoy some mildly quieter times :slight_smile:
Thats what I use also about ever 10th print or so I wash it off and redo it, haven’t had a bed probem with this method. I usally spray and even coat on then put it in the printer and set bed temp to 50 and then wait until it is dry!
I don’t use any adhesive with the PEI Textured plate when printing PETG. I’ve not had any adhesion problems.
That’s why you use hairspray or glue stick to help release it when the plate cools.
PEI (polyetherimide, AKA Ultem) is fully chemically compatible with isopropyl alcohol, and will not be broken down by it in any way. One of the material’s primary selling points is its quite broad chemical resistance.
In terms of relatively common household solvents, it’s acetone you want to keep far away from it, as that will cause pretty much immediate damage to the surface.
I use Magigoo on every print with no issues on the PEI plate
I went with the water dissolved gluestick method and used one of these larger cake cream cards to nicely scrape off the excess and then put it in the printer at 70deg and it nicely caked on almost invisibly to the plate.
This is necessary for the PETG-CF filament that sticks way tooo well and destroy the PEI sheet it is printed on without a separation layer such as gluestick added to it. You can see the slight matte sheen on the PEI sheet. That is exactly what I want.
It seems that keeping the textured plate clean is the key.
I wear cotton gloves, so when I handle the plate I don’t worry about greasing the surface.
No glue just ipa and if its petg I will use so.e wi dex so it doesnt stick so well.
None. Glue sticks are a band-aid solution.
Get yourself a Wham Bam PEX plate and you’ll never have an issue again.
The digital blue company is called overture
2nd that.
I’m still on my first aerosol tin 2 years in. Takes just the lightest of spray.
I use ‘Panel Wipe’ - an alcohol based preppie that car painters use. Flashes off really quickly and is really mild.
Just have to remember to spray the plate away from the printer.
On the textured PEI plate the only time i use glue is occasionally on abs/asa or petg for the PA lines in the front to make them a little easier to remove. Otherwise no glue needed. Abs at like 105, petg anywhere from 75 to 85 depending on the roll, and pla at 60. Only time anything comes off the plate is when its tall and i dont have a big enough brim. I clean my plate once every 1-2 months (i think) with IPA. I printed a handle for the bed so i can remove it and wave it aroud to cool it off without getting my hands on it lol.
I’m new to printing and just recently bought a p1s with the textured plate and have had issues with things lifting off the plate. But from what ive been reading in here is to keep bare hands from touching the surface and to use IPA to clean?
Not sure where the IPA recomendation came from but is is trouble prone. Wash with dish soap and hot water, dont touch after its clean. And you will have to wash the plate regularly.
I agree but some plates are recommended IPA. I have 3 plates I’d rather use IPA than just soap and water. My Carbon Fiber plate, the powder painted Ultem textured, and the PEX plate. They’re recommended with IPA so it depends on plate.
Never use IPA on a Supertack or like plate.
