What is causing this sound on my X1C?
My printer is well maintained, lead screws greased and the rods oiled. Moving the build plate up seems fine but when it’s travelling downwards, it causes this horrible sound
Video
I had exactly that sound some time ago. In my case it was the timing belt for the z-axis, touching flanges of one of the pulleys.
When you turn the printer to the side, you will see a belt driving the three z lead screws. The edge of the belt can slightly rub against the flanges of one or more of the pulleys. A small drop of oil applied to the sides of the belt completely solved the squeaking for me. I don’t remember which type of oil I used.
Just asked ChatGPT and it insists that oils are not suitable because they can damage the belt material. Instead, PTFE dry lubricant is an option. I wouldn’t spray anything onto the printer but spray it onto a cloth and apply it to the edges of the belt only with the cloth.
  1. this is correct, it is the heat bed (Z) belt system. The H2 I have does it as well. My P1 and X1 (well that one wasnt fully mine) never did, but I guess those were lucky.
  2. This correct; there is a chemical reaction between oil and rubber. Certain combinations are OK but if you don’t know which, best to avoid completely.
Eponymous is spot-on regarding the source. I had the same issue about a year ago after performing maintenance on my printer. You can use a silicone lubricant which will not arrack the rubber belt. I would also check the Z belt tension and be careful to tighten the screw with the carrier for the idler pulley straight and level.
I have this in one of my collections in case it returns. I have not tried it.
A silicone oil or grease will not damage the belts. Super Lube is a common brand name; their grease is also suitable for the Z-screws. I use Sil-Glyde becasue I have several tubes from a store-closing sale.
