What settings to prevent small details & edges from being rounded?
I would suggest dropping your accelerations for the inner and outer walls, and using the variable layer hight option go over to the side bar and toggle up to the overhangs where you can left click on the highlighted area to drop your layer hight
I don’t bother with the automatic variable layer hight but opt to do it manually and get nice sharp overhangs
It might also help in the filament profile under the cooling section to increase the layer time from 4 to 8
Also try selecting the Precise Walls option if you are using Orca to help speed things up a bit
