My nozzle seems to have a higher failure rate these days. This is my 0.4mm nozzle with a recent print. It seems to have clogged up and I also took off the PLA from the nozzle and included a photo of that as well.
Interestingly, you had exactly the same issue seven months ago. How did you end up resolving it back then? Unfortunately, it looks like you never followed up on any of the suggestions you received, nor did you post the solution that worked for you.
First thing I would start with is the definition of the term you are using here.
That’s not a ‘clog’. That’s a ‘clump’, which is usually caused by material not sticking to wherever it’s supposed to be. Usually the bed. It then just starts wrapping around the nozzle. The reason it matters is because a ‘clog’ has an entirely different solution that is so far removed that it’s almost completely unrelated to the problem here.
Clean the bed with unscented dish soap and water. Avoid touching it with your hands and transferring skin oils to the bed. Don’t use alcohol to clean the bed. Things like that.
If that doesn’t work, increase the bed temperature for your filament by 10 degrees and try again.
I would simply put a new nozzle on and see how that works.
And try a calibration.
The terms in this 3D printing sport are often quite childish. A wider support is called a brim. I liken that to somebody looking across the cubical farm and seeing a cowboy hat. “Yeah, I need a wider brim!” Oye Vey!
You DO keep some spare parts, right? You have much to learn Grasshopper.
