Who has changed the routing of the PTFE guide tube?
Mine is still a work in progress. However, once I switched to the BBL tubing with a larger ID the friction problem for bends and longer lengths is not as important.
So to get the PTFE guide off is it just force or am I missing something I really don’t like the guide I think it puts too much pressure on the tube.
I am not sure what you mean. What guide are you talking about?
The rubber one that the ptfe tube goes thru at the back of the machine.
I am not using that part in my set up.
That’s my point I want to remove the part so I don’t have to use it. It looks like in your picture your removed that part.
Yes I did. I really want to have a much shorter path than I do now, but I managed to keep all the bends reasonable and make changing filament easy.
Do you have this part as printable Part or do anybody have this part for printing?
grafik
I’m not sure anymore, but I think it was part of the mounting bracket for stock cable chain, I used before I was using the original one for my P1P.
