Why can my A1M remember all my past prints, but my X1C doesn't?
A title suggests.
I can tap my A1M, select print, and it will print a design from a few weeks ago.
I do the same thing on my X1C, and the cache is empty except for the last item.
I have to manually send the sliced print each time from the PC to get the X1C to print (unless I need an exact copy twice in a row).
Is there a setting I’m overlooking?
Thanks
The A and P series printers store prints on the SD card as they don’t have onboard memory. The X series stores each print internally BUT if you add an SD card and turn on “Save print to SD card” you can reprint past prints from it.
The other option if you sent the print via the cloud is to use the Print History in the Handy app to trigger a reprint.
