Why is my bed temp 45 C?
I’ve been using the Biqu Frostbite plate for a couple of months and it solved my adhesion issues. I’ve been running a print for 12 hours with about 5 hours to go.
Models started coming off the plate. I see that the bed is only 45 C. I double checked and all the filament profiles are set to 55C. Where do I look to see what’s overriding my settings?
And I assume there’s no way I can force the temp mid-print.
Sounds like you may have selected the SuperTack plate which default temps are 45C. Double check you have the right plate selected.
You can adjust bed temperatures after it’s already started printing without issue.
I do have Supertack selected on purpose. But it’s always used the bed temp from the filament profile. What am I missing?
I bumped up the bed temp manually. That’s good to know.
Did you adjust the temperature on both the initial layer and other layers? You’ll want to change both.
Yes they are both set to 55. It hasn’t happened again since I posted, and I’ve printed many plates. A weird fluke I guess.
