Why is my print so bad
I have been having this issue for a while. While I sometimes get a proper print, why does this happen??? this is a standard benchy. 4mm nozzle.
Extruder is slipping, or the extruder stepper motor/stepper drive circuit is failing. Problem gets worse towards the end of the print because everything is hotter, and heat causes the issue to happen to a greater degree.
Start by taking the extruder apart and cleaning out any build ups of plastic, make sure things can turn smoothly.
To me it looks like you either have a partial nozzle clog or the thermal grease has dried out.
See this thread for similar results.
I replaced the hot end, and I still have the same results. I think this rules out the thermal grease. So I guess I have to figure out how to repair the extruder next. Thanks for the replies!
