Why is studio forcing us to now have to redo speed settings?
You used to be able to swap machines around without having to redo the speed settings, why has this been introduced since the H2D came out and now, even swapping between the older machines causes this problem. Even between an A1 and a mini. Why can’t the speed setting stay the same between machines, this doesn’t make sense.
This for example, open project, slice plate on one machine, swap to another to do a 2nd plate, you have to redo the speed settings. I slow all my prints down from whatever the default is, I sometimes have to reset the speed over 5 times per print job.
click save on the profile
next time just select the profile
