So I am confused about this one or my eyes are playing tricks on me. If I keep the line width the same in the settings, print the same object in vase mode with 0.94 flow ratio and print it with 0.98 flow ratio, would the walls of the one with 0.98 flow ratio be thicker?
Yes, but you’d be overextruding.
It is usually better to calibrate the flow ratio correctly and then just specify a wider line width.
It saves a lot of hassle when doing the next print or wondering where the waves in a base of a vase mode object come from ![]()
