X1C LAN mode connectivity problem
Hello everyone
I’m having a problem connecting my X1C in LAN mode to my PC. I’m trying both ORCA and Bambu Studio, and the error Code =-1 appears every time.
My PC is connected to an Ethernet cable, so I tried my Wife’s Laptop and installed Orca Slicer on it. It connected to the printer without any issues once I entered the Access Code, so I think the problem is related to the Ethernet connection on my PC.
I made sure that my 2.4 GHz and 5 GHz connections are enabled from IP 192.168.0.1
I tried disconnecting IPv6 Firewall from there… no Avail
I tried the Windows firewall OFF, same, no results
selecting Band steering ON or OFF… nothing
Network from Private to Public and Vice versa…Nothing
What else should I try? Because now I’m giving up.
Regards
Daniel
Strange I’ve in the middle of a multiday print and just lost the video feed with the same code -1 error , I not changed anything in the last few days .
My first guess was my DHCP server had changed the IP address , but no the same IP and bambu studio says it is on-line but will not connect , so is a H2D and X1C problem ?.
