X1C LAN only mode connectivity issues (solved)
Hello world :slight_smile:
I had connectivity issues with my BambuLab X1C from Linux application running on FreeBSD. After troubleshooting was caused by firewall blocking printer broadcasts from port 1990/2021. This can be fixed by adding firewall rule that accepts packets from printer IP src-port 1990,2021 to ANY address (not only to β€œme”). After adding this rule all works fine, connection is initiated by the host so stateful firewall will accept following connections, it is possible to upload models, view camera, etc.
I have asked BambuLab to provide table with all network ports and protocols involved, and here it is:
https://wiki.bambulab.com/en/general/printer-network-ports
I hope this helps anyone who faces similar issues :slight_smile:
