X2D hot end cooling fans run well after print has ended?
I’ve had to replace both hot-end cooling fans on my X2D within the first 300 hours of use. This morning, I pulled a print off the plate that had finished several hours earlier.
Both fans were still running. Is this normal? Is this why I had to replace both fans?
Don’t know much about this issue, but as a fellow X2D owner I can confirm this doesn’t happen on mine.
Thanks, I’ll keep an eyeball on it.
Did you happen to see the hotened temp? I know mine runs at least until the nozzle cools down to a certain point, maybe it’s an issue with it cutting power or something is hanging and not finishing the printing process?
I know last night it was still hotter than the unused right nozzle, so that may be it. Thanks.
Do you print more engineering stuff?
