I have got my first printer, a P2S for about 1.5 months and is generally happy with it so far. The only complaint I have is the noise it makes when the bed moves up and down in pre-printing procedures . There has got to be some ways to quiet it down because the same Z motion speed in these procedures can produce very different noise level as shown in this video I took yesterday : https://www.youtube.com/watch?v=o-gCIuILZfg . Does anyone know the method ? I have tried changing the start-up G codes according to the info given by AI but just managed to slow down some of the Z movements which can be made super quiet. The others seems to be not changeable as according to AI, the speed is controlled by some macros in the firmware instead of the start up G codes.
What’s the issue with the sound of Z axis travel?
You can absolutely reduce any Z travel motion speed, and therefore sound level via G-code.
You can’t change stepper motor tuning, that isn’t available to users.
My neighbor is complaining ….
You are entitled to reasonable enjoyment of your home during daytime hours.
Beside the very possible speed change for Z movement behaviors, you have other options:
You could also hang a sound absorbing blanket on the wall adjoining their apartment.
You could use a 18x18 concrete patio block and a sheet of styrofoam to dampen sound transmission between the printer and the table.
You could use sound damping adhesive materials to try to dampen resonance happening on the printer itself.
Seems ok, ensure the rods and screws are well lubricated after use, and or before a new start up.You must have very thin next door adjoining walls to upset the neighbours So a P2S is no good for neighbour newly weds or you suffering from flaterance .What about the vibration checks? , that might turn them on.LOL
Did you do something with the gcode right when you got your printer. I do not know much about what is going on with the printer calibration that manifests itself as different vibration tones but you might want to put it back to stock. We hear the sound but but the printer is using it in a non-sound based calibration that maybe soeone could elaborate on. I’d be interested in better understanding that myself.
I get that sound but I am hard pressed to thing people would complain about it. First it doesn’t take that long and second, while noticeable I would not consider it annoying nor would I expect it to be offensive to the neighbors.
