Z offset adjustment?
Here is a suggestion what you could do to support PETG only adjustment:
NOTE: I am yet to test the +0.02… I tried -0.02 and that was still too deep. As cool as the Bambu X1C is it is not well tuned for PETG printing out of the box… and even babies can print with PLA just fine… so it is up to us… tuning it in ALSO means retraction, wipe and z lift when travel settings… unfortunately not all of those things are included in the Bambu slicer but I am currently tuning in an excellent filament to match the performance of my Prusa, which can print with any PETG any day perfectly, no failed prints… I am confident I can get there with the Bambu too.
;===== for Textured PEI Plate , lower the nozzle as the nozzle was touching topmost of the texture when homing ==
;curr_bed_type={curr_bed_type}
{if curr_bed_type=="Textured PEI Plate"}
{if filament_type[initial_tool]=="PETG"}
G29.1 Z{0.02} ; for Textured PEI Plate with PETG
{else}
G29.1 Z{-0.04} ; for Textured PEI Plate
{endif}
{endif}
Do you know if this, Z offset in the Beta works?
I will try it in 0.02 increments until the visible layer lines disappear.
After posting the original question I remembered I was getting perfect layers with the original 0.4mm nozzle, I have been getting the issue with the 0.6mm and 0.2 mm nozzles, I am away from home at the moment but as soon as I return I will change the nozzle back to 0.4mm and try the offset if it is still showing layer lines.
